It is currently Mon Jul 28, 2025 1:09 pm
PostPosted: Fri Oct 14, 2005 2:45 am
Ok, maybe I am just being blind again but, where can I get a few redwood tops. I haven't looked in a while but don'tremember any of our suppliers here having any.
thanks in advance
PostPosted: Fri Oct 14, 2005 2:47 am
there are three sources here on the OLF that I'm aware of.
Hank Mauel
Colonial Tonewoods
Don Williams
PostPosted: Fri Oct 14, 2005 2:48 am
on not on the olf but I've gotten great redwood from before is Dave Maize
http://maizeguitars.com/woods/index.htm
PostPosted: Fri Oct 14, 2005 3:21 am
What do you need, Frank?
I have a good supply of top sets that will easily build any size guitar you might have in mind. Also, if you are doing a small guitar (Parlor, etc)I have a "miscellaneous" stack of tops that are odd sized and sell for a lot less. The primo stuff usually goes in the $50 a set range. This is the same wood I supply to Geoger Lowden, James Goodall, LMI and a host of individual builders here and on other news groups.
PostPosted: Fri Oct 14, 2005 3:40 am
Just curious, Hank, is the redwood you have flamed or straight grained?
PostPosted: Fri Oct 14, 2005 7:44 am
[QUOTE=JeremiahB.] Just curious, Hank, is the redwood you have flamed or straight grained?[/QUOTE]
I have only a handful of flamed sets that I would deem suitable for tops. All the rest is very tight, straight grained woods from old blown down trees.
Here's a pic of the flamed stuff:
PostPosted: Fri Oct 14, 2005 7:46 am
That sho' is nice Hank! But then so are all your redwood tops from what I've seen...
